400rwhp LE1 Heads with CC306 Dyno numbers
Just off the dyno
97 T-A m6
LE1Heads, cc306 ,4.10 gears, LS1 lid conversion, 58bb tb, 30.lb injectors ,full bolt-on's
400.4 rwhp
365 rwtq
LE1 heads with stock valves, ported by the master himself, and tuned by Joeseph Y. aka(Kryckter)
Dyno run 1. (base tune for a heads cam car)
A/F was 14.1 up top
393.8 rwhp
Dyno run 2
A/F was 13.1 , Down on power, and torque accross the board
384rwhp
Dyno run 3
A/F was 13.5, adjusted the timing according to altitude and setup
400.4rwhp
365rwtq
Crongrats to Zach the owner, thanks to Lloyd for ported the heads, mad props to Kryckter for the tune, most of all B-rad at Alley Speed for the install.
97 T-A m6
400.4 rwhp
365 rwtq
![Bow](https://www.camaroz28.com/forums/images/smilies/bow.gif)
A/F was 14.1 up top
393.8 rwhp
Dyno run 2
384rwhp
Dyno run 3
400.4rwhp
365rwtq
Re: 400rwhp LE1 Heads with CC306 Dyno numbers
Damn! I need to get in touch with this guy that did your tuning. I've got a set of home ported heads that I assume are 20cfm over stock. I've also got a gm847 cam. How much cfm over stock are LE1 heads?
Kryckter did the tuning, on Zach's T/A and on his own freak 417rwhp LE2 setup. He has the tricks for these setups down.
Yes it is a stock bottom end 140,000 miles and going
One of Lloyd's LE2 flow sheets(not Zach's heads)
2 136/102
.3 192/137
.4 238/164
.5 265/183
.6 271/188
2 136/102
.3 192/137
.4 238/164
.5 265/183
.6 271/188
Ya , Zach and Joe are on there way back from Lubbock right now, i'll have Joe or myself email it to you tonight. Joe said it was over 300rwtq from 3,000-5,500rpm's.
EDIT
I just looked at the tq curve on the graph, and its above 350rwtq from 3000-5700rpm's
EDIT
Kryckter put down 400rwhp 361rwtq on stock bottom end, then on his forged 355 he put down the 417rwhp and 381rwtq. I'm not sure if the little small block can put out any more torque on a hyd roller, unstroked, stock bottom end. But it would be nice if it did.
