410rwhp from LE heads and 847... (graph inside)
#31
Re: 410rwhp from LE heads and 847... (graph inside)
BTW here is my dynograph, I lost my SAE one but it was about 400rwhp just a bit under if I can remember, this is the actual rwhp it put down with the GM847 cam I had, I've since changed to the LE3 cam, dyno numbers will come next weekend.
http://www3.telus.net/bunker/DSCN00551.jpg
Then again mine are Dynojet numbers
#32
my numbers were made through a dynojet as well... SAE corrected with a massive valvetrain screwup going on at 6,000RPMs. i'm readjusting the valves monday and welding in the cutouts next week then it's back to the dyno. i'm sure you will all enjoy the results.
[New Jersey] Cure those winter blues with the NJFBOA!!!
njspder
Middle Atlantic
01-08-2015 11:13 AM
squarehead
11-21-2014 08:02 PM
