48MM TB with cc503 and ported heads?
My engine is finally coming back together! Thanks for all the help along the way. Its almost time to put the heads and intake back on but i've been stuck on whether i "need" to upgrade the throttle body to something large.
stock bottom end, 30lbs injectors, cc503 cam, ported stock castings and 1.6 pro mags.. Am i hurting the engine much by staying with the stock tb ?
For now im just trying to get it back together and enjoy the car. I can always upgrade to a larger TB later right? This will be my daily driver so im not too concerned with leaving 5-10HP no the table..
As long as it wont run badly.. im happy.
you don't really need a bigger tb.. its if anything possibly a 10hp gain. i have a stocker on the lt4 engine i put in my trans am with a xfi 280 cam. runs fine. i only have a 52mm on my corvette, its a 383 with le3 lt4 heads and a huge cam..
