503 cam install
503 cam install
Im getting ready to install the 503. I just recently installed crane 1.6 sa rr, and lt4 springs. Im looking to get some new springs with the cam, and was wondering if there is a set out there that would work, but is cheaper than the 918s. Also wondering if I need new retainers, if so what kind, and pushrods, also what kind. (ive got 130000 miles) Thanks
Crane makes a good spring kit that is popular on here. It's cheaper than 918's and stouter than those LT4 springs. I'm too lazy to do a search right now, but I'm sure it's in this forum and on Summit. (10308-1 maybe???)
You need to get chromemoly pushrods. Stock length should be fine for you. There are plenty of brands that make them, just stay with a major one and you'll be fine.
I am renting a shop with a lift for the cam install, so I need to order everything before I start working, so I dnt know if I will be able to measure the pushrod length before I order them. Is there anyone that has a similar setup that could tell what worked for them, or any ideas as to what size I should use. I know stock is around 7.195.Is that what I shld get? Also cld I maybe start with a longer set, and grind them till they fit. Sorry about all the questions, ive never done this before and I dont have the time, or funds to screw up. Thanks for your responses
Grinding the pushrods would be out of the question. I'd recommend getting a length checker as well, and then driving to a local speed shop to get the right size... or order several sizes and hope one works, return the rest?
Stock pushrod legnth is 7.200, the correct size will be dependant on your; deck height, head gasket thickness, wether the heads have be resurface and if so how much, rocker design, vavle stem height, lifters being used, cam, and wether the block has been align bored. (they may be more factors I forgot)
No, you can't just grind them shorter.
New pushrods may sound like overkill, but I think they should be considered a necessity. If you must get the hardened ones, fine, but I think most would agree in recommending that you get some chromemoly ones.
F(ast)-body
02-26-2003 09:05 AM
