52 or 58 mm throttle body
I am shopping around for a bigger throttle body. My 95Z has a couple of bolt on mods right now, but i am going to be installing headers and a cai. I havent seen a lot of people using the 58mm throttle body, why is that or am i just looking in the wrong places? Which is better to have installed 52 or 58? thanks
GM High Tech Performance did a throttlebody sway on a LT1 Camaro several moths ago from a 48 to 52 to 58mm. Between then 48 to the 58 mm they saw a 3 hp gain. Unless you plan to run big HP over 500 or higher a 52mm will do just fine. I ran 12.89@102 on a head and cam with a higher stall and 3.73 gears in a 4500 lb boat with a 52mm throttlebody. And with my new setup I kept the 52mm. Good luck!
HVY SS
HVY SS
