52mm tb or EWP on a hotcam car?
How much if anything will i notice from installing 52mm tb on my car? Right now it has a hot cam, mac-mids, and a cai. Would i be better off getting a electric water pump, or 52mm TB?
Before anyone says a TB cost to much for what you get, i'm planning on getting a used for $150ish. I plan on getting both before i send the pcm off to get it tuned in a few weeks. i just want to know witch one i'de be better off getting first.
Also i think i've seen that the openings on the stock intake are 54mm, is that true?
Thx guys
Thx guys
My priorities would be to get it tuned first then i'd go E-waterpump as you'll get more gains than a TB. You do need to make sure you get a tune after your TB though because you have an A4 car. I personally wouldn't waste the money on a TB with your mods. After heads it might be a good idea.
I seen some place on here that a 52mm tb will get around 7rwhp on a stock lt1. Would a EWP really help more then that?
:edit: just looked at your CD page, and damn i want to have sex with your car. that thing is freakin beautiful.
Thanks for the compliment my car has under gone a lot of changes since those pics. I now have a 97+ Camaro dash and the new bad *** Hella 90mm head lights. Now that my GF has a new bad *** 5-6 megapixel camera i'll probably take some good quality pics in a nice setting.
www.ws6.com has graphs of gaining 6.5 rwhp with an E-pump. Many others have documented 8-10 rwhp gains with just the pump, and it'll help keep your car a lot cooler. The stock pump flows 25 gals per min at 6000 rpms and the electrics are 37 gals per min all the time. I can't believe gains of 7 rwhp with a 52mm TB unless it was on a big heads and cam car.
oldschool
02-09-2016 09:21 PM
