#6 Fuse Issue
#6 Fuse Issue
I am having a problem with the #6 fuse blowing. I realize this controls many diff. functions of the car.
1) We have ruled out the fan circuit as we can pull all 3 relays and the fuse will still blow the instant you turn the key on.
2) I have checked the O2 sensor wires and have not found a short. The car no longer has an air pump on the car and hasn't for a long period of time.
3) The reverse lock-out has never worked on the car since the M6 was taken out.
Is there any where I can find a complete wiring schematic for this circuit?
Anyone have any ideas?
Re: #6 Fuse Issue
fan relays
O2s
reverse lockout
skip shift
EVAP solenoid
EGR solenoid
All these things are controlled by underhood fuse #6. If not a bad device, there is a ground in the wiring somewhere.
O2s
reverse lockout
skip shift
EVAP solenoid
EGR solenoid
eanhl2004
04-04-2015 12:01 PM
fpete1992
12-11-2014 03:51 PM
