6 month old spark problem (HELP)
I wrote this thread 4 months ago and this was the way the car was acting at the time:
"Been having this problem for the past 2 months now and havent been able to drive the car for fear of getting stranded. Most of the time, the car will start and run normally for 10 minutes or more. During this time, the car runs flawlessly (no miss, rough idle or anything). At some point after that, the engine will completely quit without any sort of warning. Sometimes it will start back up and run fine, then quit again the same way, or it wont start back up at all. Had it out the other day, it lost power, backfired, regained power and then stalled a minute later."
Now the car is sitting in the driveway and will not start whatsoever.
Where do i go next trying to track down this issue. I have already replaced:
- Opti distributor (cap and rotor looked fine and were not replaced)
- Spark Coil
- Ignition Control Module
- O2 Sensors
I have checked and verified that these properly work:
-MAP Sensor
-TPS Sensor
If i remember correctly there is no spark whatsoever at the coil.
Someone please give me some advice as to what to do next. I havent driven the poor car in months and because i recently had my ACL repaired, i cant drive my 6-speed WS6
- Spark Coil
- O2 Sensors
-MAP Sensor
-TPS Sensor
Sounds like you're having problems when it goes into closed loop. This is usually an O2 sensor problem.
Try unplugging the O2s and drive like that. If you don't have the problem then that confirms that it works in open loop and not in closed loop.
Is the PCM stock?
Is the PCM stock?
10-31-2016 11:09 AM
grabbem88
03-18-2015 01:25 PM
