6 month project list... what am I missing?
Ok people, I have been trying to get this list finished and eventually get all the parts ready to be assembled some time around October all at once. This is meant to be a very reliable touring and open road racing car, I left out a lot of the suspension and weight saving mods till a later date when I have more sufficient funding, but this pretty much sums it all up...
BRAKES
Baer Eradispeed Rear 11.540" x 0.810" Rotors, Slotted, Zinc Washed, Drilled
Baer GT+ Kit PBR 2 Piston Calipers 13.150" x 1.50" Rotors Slotted, Zinc Washed, Drilled
DRIVETRAIN
B&M Ripper Shifter
LS1 Aluminium Driveshaft
POR 15 Metal Mask (1 Pint, used to coat rear end housing, axle tubes and brackets)
Thunder Racing Complete Gear Package
Tremec/Borg Warner T56 Conversion
ELECTRICAL
Moroso Quick Disconnect Starter Harness (74245)
Moroso Sealed Battery Box (74050)
Taylor Convoluted Tubing and Fittings (multiple lenghts and sizes)
ENGINE
Accel 30Lb/Hr Injectors (150830)
Aeromotive Adjustable Fuel Pressure Regulator (13107)
Comp Cams Hi-Energy hardened pushrods (7808-16)
Comp Cams OE Replacement Hydraulic Roller Lifters (850-16)
DEI Heat Shields
DEI Spark Plug Wire Sheath (010409 x2)
DEI Starter Heat Shield (010402)
Dupli-Color Engine Enamel
Fel-Pro Valve Seals
GM LT4 "Extreme Duty" Timing Set (12370835)
GM LT4 Hotcam Kit (12480002)
GM LT4 Valve Cover (12552321)
GM LT4 Valve Cover (12552322)
GM LT4 Valve Cover Bolt Kit (10108675)
GM LT4 Valve Cover Stud Kit (10108674)
GM Optispark Distributor
Holley Performance In-Tank Fuel Pump, 155 LPH (12-912)
MAC Headers
Moroso Blue Max Plug Wires (72526)
Moroso Cold Air Induction Kit
Thunder Racing LT1 Cylinder Head & Camshaft Swap Gasket Package
INTERIOR
Bulldog Security Alarm (1101)
OE Dash Panel
OE Manual Console
LABOR
(*apply DEI heat shielding to firewall)
(*assemble engine)
(*clean and refurbish all wiring and plumbing)
(*clean underbody)
(*relocate batter to spare tire area)
(*remove stock heat shields)
(ALJ Spec dual exhaust fabrication) (see attached data sheet)
(Big O Tires wheel mounting, tire balancing, alignment)
(Morgan's Machine clean intake and cylinder heads)
(West Coast Powdercoating ceramic coating exhaust system)
(PCMForLess.com Tuning)
SUSPENSION
BMR Strut Tower Bracing (chrome moly, red) (MSTB001)
Global West Sub Frame Connectors (905)
SLP Stage One Suspension System
BFGoodrich g-Force T/A KDW (275/45YR17 x4)
GM ZR1 Super Sport Wheels 17"x9" (10214046 x4, used)
However, I would like to know... what am I forgetting? A few Q's I got are as follows:
1.) Does the LT1 use most standard bolts as the original SBC so I could use the standard SBC ARP fasteners.
2.) As far as a clutch goes, what do you guys recommend, I will be running a lightweight aluminium flywheel, and power will be around 350-400hp max.
Much thanks!
BRAKES
DRIVETRAIN
B&M Ripper Shifter
ELECTRICAL
ENGINE
DEI Heat Shields
Fel-Pro Valve Seals
MAC Headers
INTERIOR
OE Dash Panel
OE Manual Console
LABOR
(*assemble engine)
(*clean underbody)
SUSPENSION
Much thanks!
10-31-2016 11:09 AM
ChrisFrez
03-22-2015 07:00 PM
