87 Hyd Roller cam in a Lt1, whats it take?
To run an 87+ Hyd roller cam in a LT1, is it just the dowel needs to be modified? 87+ use retainer plates like Lt1s. Will the pilot hole being shallower effect any thing?
Re: 87 Hyd Roller cam in a Lt1, whats it take?
Originally Posted by speedmiser
I don't think it will effect anything if you plan on running your non-vented opti. I don't think the spinned opti drive goes far enough through the cam gear to protrude very far into the cam face / pilot hole (if at all). Been awhile since I messed with the non-vented though. If the shaft happens to be to long, you could always cut it back on the cam side.
oldschool
02-09-2016 09:21 PM
