9:1 or 11:1 better?
Don't just look at the static compression ratio. You have to look at the dynamic compression ratio. That takes into account the valve opening and closing events, so you know what the compression really is. You can safely run more compression with a big cam.
I run shaved heads along with the thinner Impala head gaskets to raise the compression up to 11.8:1. I have a bigger cam (comp XE 230/236), so the dynamic compression ratio is safe. I run it on California MTBE 91 octane with no problem.
you shouldnt have to run 100+ octane until its over 12.0-12.5:1.
ive read many posts about this, try doing a search. be surprising what you will learn.
my CR is 11.3:1 and runs fine with 93 octane, i saw no improvement at the track while running 100 octane.
back to the question
1. as a rule n/a more compression=more hp
i dont think i would go higher than 11.5 on pump gas
2. you cant run boost on a high OR motor, s/c or turbo motors like to use a CR around 8 to 9:1
3. N20 (the best power adder IMO) doesnt require a low CR like turbo or superchargers
hope this helps
hope this helps
Originally posted by JoeliusZ28
my manual claims 10.5
If you are not ruuning a power adder, go 11 to 1, that's what I'll be doing.
