911!Help ASAP! Middle of Header install
i am in the middle of installing rksport headers in a 94 camaro and the drivers side won't go in without removing the steering shaft but i don't know how to remove it. the install i read didn't say anything about removing it but i don't see any other way of getting it in. i already remove the one bolt that seems to attach the steering joint, but i can't seperate it. anyhelp would be appreciated.
If it helps, when I put in my ASM headers, the steering shaft had to come out, but I got everything out from the top. One bolt at the top of the shaft, one at the bottom, and a good rap with a hammer set it free. Cake after that. Just be patient with it.
NewsBot
12-30-2014 09:40 AM
NewsBot
12-28-2014 06:20 PM
