92 rs with an lt1 swap
were can i find things like headers and piston rings main bearings rod bearings fuel pumps for my 92 lt1 swap. i have a v6 efi pump will it work with a lt? also will i have to change my motor mounts from my previous engine on to the lt so it will fit? what about accessories do they all fit in? how can i tell the year of the lt1 by looking at it? does anyone know were i can find a list of block #s to tell what years they are?? and finaly is it a good idea to change bearings and mains on a used(50k) block without machining the crank?
thanks
jeff
thanks
jeff
Re: 92 rs with an lt1 swap
http://www.fparts.us
http://www.tacreationsusa.com/
http://www.camarosource.ca
www.thunderracing.com
www.tbyrne.com
www.summitracing.com
First two - used parts
3rd- info
last - performance parts
You'll need a lot of stuff, but it's all been done before, so it shouldn't be too bad.
www.tbyrne.com
3rd- info
