93 Intake and rails on 95 Engine
OK, so I know the 93 intake will not flow better than a 95 intake or if it does the difference is negligible. I would like to run the 93 intake and fuel lines because I like the looks of it better. Does anyone know if this will cause any problems running it on my 95?
Re: 93 Intake and rails on 95 Engine
The only issue would be the fuel line connections. They're about mid way front-to back on the 93 fuel rail and at the back on the 94+ rails.
You'll have to transfer your TB and injectors...both were different on 93's
I remember reading somewhere that the 93 fuel rails are engineered for batch-fire injection, while the 94+ rails are engineered to support sequential fire. Whether or not you'll have a pressure variance between firings I'm not too sure. Fact is they are not the same.
I'd stick with the 94+ rails if possible.
Found this in Wikipedia.
The 92–93 LT1s used speed density fuel management, batch-fire fuel injection and a dedicated engine control module (ECM). In 94 the LT1 switched to a mass airflow sensor and sequential port injection
Like I said whether or not this could be a problem I'm not sure, but if it were my motor I'd just keep the 94+ rails.
Just look at the way the two rails are connected in the 93's, compared to the front cross-over pipe in the 94+ rails. They had to have a reason for those differences, and the batch-fire vs. full sequential might be the reason.
There also appears to be a pulsation damper on the 93 hard lines.
10-31-2016 11:09 AM
hotrodyou1
12-20-2014 10:05 PM
07-04-2005 05:00 PM
