93 lt1 can't be tuned at local dyno shop?
Old 07-03-2011, 04:09 PM
  #16
MikeGyver's Avatar
Re: 93 lt1 can't be tuned at local dyno shop?
Originally Posted by Colin
MikeGyver,
How so? Because you can use LT1Edit? Or you have SEFI? OBD-I LT1 runs just fine but it takes a bit more effort to tune. I'm happy with mine but struggling to get it running for the first time. The AutoProm is a nice unit and cheaper to purchase and run than LT1Edit.
95 is obd1, it's better than 96-97 obd2, and lt1edit is crap. tunercats+datamasters+cable for what $150 (another $100? to register datamasters) and unlimited tuning on any number of 94-95 lt1s in speed density or maf mode. Flash based pcm, no eprom or eeprom chips to deal with.
I don't know if you'd have to change the engine harness which would be a pain, but the 95 system is 1000000000000x nicer to work with.
MikeGyver is offline
Old 07-03-2011, 10:50 PM
  #17
dennis5374's Avatar
I can't even finnd a 95 pcm too buy but if i do ill prolly get a painless wiring harness also
dennis5374 is offline
Old 07-04-2011, 06:17 AM
  #18
koolaid_kid's Avatar
+1.
I own LT1Edit, and it is junk IMHO. No support, poorly executed, lacking features, etc.
BTW, I picked up a couple of 94-95 PCMs for around $50 each, so they are out there. Also, IIRC you can use the PCM of any vehicle with an LT1 derivative, such as the iron head Caprice and RoadMaster.
koolaid_kid is offline
Old 07-05-2011, 12:37 AM
  #19
MikeGyver's Avatar
In tunercats, once you realize you can manipulate the 3d graphs graphically (not just numberically) you can realllly dial in and smooth the maps and get the car running awesome, even running a 2bar map sensor.
Old 07-05-2011, 01:05 AM
  #20
ACE1252's Avatar
Damn.....I have DST and didn't know you could do that. I just tried it and sure enough it works. Just click on the intersection of two lines, it highlights the cell, and you can adjust it up or down by the graph.
ACE1252 is offline
AdsoYo
05-02-2018 03:21 AM
DirtyDaveW
12-01-2016 05:37 PM
ezcheeze15
08-26-2002 01:28 PM
Burn_Out
08-18-2002 08:49 AM
Zomie
07-22-2002 07:43 AM
Quick Reply: 93 lt1 can't be tuned at local dyno shop?
