93 Z28 all stock
93 Z28 all stock
im having problems with my car it runs great sometimes and sometimes it will backfire a lil it sounds like its coming from the intake and i've noticed it only does it in gear it dont do it in park if i rev it up
Re: 93 Z28 all stock
Under what conditions does it backfire - cold engine, hot engine, wet weather, part load, wide open throttle?
Have you scanned it for codes?
Put your car info in a "signature" - year, model, engine, trans, and the fact it is titally stock - rather than having to type it every time in the sub-topic field? That way we would know which tranny you have, for example, which might affect the answer.
This will then show up every time you post. It'll help other figure out what your issues are based on your mods....
Andrew, check the firing order and make sure all your other ignition connections and components are good. If that stuff is all good, you could have a cracked cap on your opti, or your opti could be on its way out. Are you having any hesitation or lack of power throughout driving range?
Let's try this one more time.
Very easy on a 93, since you can flash the codes on the SES light by shorting the ALDL pins.
Courtesy of Shoebox:
http://shbox.com/1/dlc2.jpg
10-31-2016 11:09 AM
01-05-2015 07:14 PM
Brandon Wittmer
12-03-2014 09:28 PM
