93LT1 into 97 Z28
93LT1 into 97 Z28
I am sure it has already been asked but with over 4200 posts, I could be here all week looking for an answer.
I have a 93 Z28 Coupe A4 that I am wanting to swap at a minimum, the motor, into a 97 Z28 Vert. It is also an A4. Motor and trans in the 93 are FAR from stock (383 that cost me $7000 while over seas and $3000 in the transmission) I know i can't use the 4L60 in the 97 which sucks but I can live with moving over to the "E" just have to get another stall converter. My question is... if i have both cars... what will I need to do to make the 93 motor work in the 97.
Re: 93LT1 into 97 Z28
You may have issues connecting the 97 engine harness to the 93 body harness connectors. Shoebox has a table of connector faces for all years.
http://shbox.com/1/harness_connector_faces.htm
