93z28 with no engine can i only use a 93 lt1
#17
Those wacky guys from CA must have ESP
How would any inspector know what year the engine is? Who would tell them it's a different year engine? DMV doesn't care about matching numbers on a vehicle. If I remember correctly, the VIN drives the inspection process, not the "parts".
#18
Re: 93z28 with no engine can i only use a 93 lt1
not to be a pain but it also seems like some things run off fuse 10 on one and fuse 2 on the other....does this end up mattering while hooking it all up or will it just work fine running say whatever is on fuse 10 off of fuse 2...i have a general idea that it will be pretty easy because most things just line right up and i know it will pry be a day or two of well i guess that wire is in the wrong spot kinda stuff...i got 2 friends to help along the way thankfully and they are pretty smart with this kinda stuff, just oblivious when it comes to camaros...anyway ill keep everyone updated once it all starts
#20
Re: Those wacky guys from CA must have ESP
I think the 93 reports differntly than a 95.It's kinda like parents,they seem to know.
#21
#22
I put a 93 trans am motor in my 94 buick roadmaster. I had to swap the bracket for the alternator, the harmonic balancer shaft, harness for the distributor, and i had to add a knock sensor because the 93 model only needs one.
#23
oldschool
02-09-2016 09:21 PM
Zpower
09-18-2002 05:33 PM
