94 Camaro Z28 misses then shuts off! Need help!
Old 05-11-2009 | 12:53 AM
  #16
JCCamaroZ28's Avatar
I already had the shop scan it for codes, and they said I think they were a 32 or 35 codes, I don't exactly remember, but its pointing to the distributor. I got a new cap, rotor, and distributor, and they are insalling it tomorrow.
The exhaust leak is because one of the three bolts that hang down broke on me when I was replacing the starter. There might be enough of the bolt left to try to put the nut back on, I've just been busy with finals, sats, that kinda stuff to really get to it.
I'll let you guys know how it goes when I get my car back.
Also, on craigslist, I found some lt1 shorty headers for $100, I'm gonna check em out on wednesday.
Old 05-29-2009 | 07:15 AM
  #17
Silverstn209's Avatar
Re::
OK, I own a 94 z28 and it sounds to be like your distributor, they tend to fail with the LT-1 engines often due to the water pump failing and weaping on to the them, considering the distributor is located directly below or if u would pretty much on the pump, and when it fails, well bye bye distributor, soo give me a shout out if i was right, let me know whats going on with it, ill probably be able to help if your still having the problem past that
Old 08-02-2009 | 07:08 PM
  #18
Ok so I replaced the cap, rotor, and distributor itself, it runs good now. Thanks for all of your help guys.
Old 08-02-2009 | 07:53 PM
  #19
Interesting, because DTC 32 is for the EGR, and there is no DTC 35. Neither of those was pointing to the distributor.
NewsBot
12-28-2014 06:20 PM
fpete1992
12-11-2014 03:51 PM
Brandon Wittmer
12-03-2014 09:28 PM
grendal
04-15-2010 05:20 PM
sleeperZ96BT
06-05-2005 09:33 PM
Quick Reply: 94 Camaro Z28 misses then shuts off! Need help!
