94 issues help please
Few problems if the youve experienced.any of them please give.me.some advice
From a cold start the car wont stay on unless you hold the gas pedal down takes maybe ten minutes and it still idles rough if you dont the car will shut off unless its given gas
If it sits for.another 10 minutes youd have to repeat the steps
Once it idled on its on I raised the hood and revd it by hand and heard a poppong sound like a small back fire
Transmission is leaking and doesn't feel like its slipping I dont.feel a jerk or kick goong in gear but i dont feel power as I should be I can push the pedal and the exhaust is loud but car isnt moving as fast as it should be
I.put the car in reverse and heard a clank sound
When I put the car into second it made like a knock from under the car like the tranny moved
Previous owner added machined heads cold.air intake and headers
i cleaned the tb and I put injection cleaner but it didnt help
Before I take it.to a shop I woild like to hear ahat these symptoms sound like thanks
Re: 94 issues help please
Basic questions:
Have you scanned it for codes?
Have you checked the fuel pressure?
What modifications to the engine and/or transmission are you aware of?
History of the vehicle - Is this a new purchase, with the problems you have discovered, or have you had this for a while, and these problems have developed over an extended time period?
Could be a problem with the coolant temp sensor. If it isn't telling the PCM (computer) the correct engine temperature, it could display theses symptoms.
Does the car still have it's catalytic converter?
Is it possible the car has a high stall torque converter?
Worn u-joints, too much backlash in the rear gears.
Possibly a broken transmission mount.
Do you mean ported heads? Was the camshaft also changed? If so, was the PCM tuned for the changes?
Best thing you can do is download a free copy of Scan9495, get a cable from Red Devil River or ALDLCables to connect to a laptop, and run a data log of the PCM while driving the vehicle under varying conditions. One of us can help you interpret the results.
https://www.camaroz28.com/forums/com...95-lt1-874306/
Popping in the exhaust can be due to the missing cat - 94 only has onen cat.
You can't put a "chip" in a 94 PCM. Fixed chip has to be flash programmed. Other than a JET or Hypertech "module" that plugs in between the PCM and its harness connector, everything else is a scam. Even the modules, and the Hypertech hand held are virtually useless.
Go here and click on the "Instructions" tab:
JET Performance 19414S, JET Stage 2 Power Control Modules for GM | JET Performance
Note what it says on the "Overview" tab:
Does your car have an aftermarket 160*F thermostat (stock is 180*)?
If someone ported the heads, they should have had the PCM tuned for the changes. I can't see anyone just having the heads ported, but not changing the cam. By installing the JET module, it may work against any tune that has been done, and by itself, with no tune, the module isn't all that great. If you don't have the low temp t'stat, the fans are going to be running all the time, but the engine isn't likely to run any cooler, because the t'stat' isn't fully open.
For vehicles modified with low restriction exhaust and low temperature thermostat.
Alex Barnes
01-24-2015 10:21 PM
