94 optispark
On a 93 and 94 F-body, the 'dowel' is actually a splined shaft. It is not press fit into the crankshaft..you can pull it right out. It can be put back with either end in but the spline is set up so it should be indexed correctly. Of course, this doesn't mean it can't go in wrong so you have to be careful.
If you look closely at the opti you can see the corresponding teeth which engage the shaft. There is an extra wide tooth that indexes things. The cam is the same way. Slide the shaft into the cam and twist it until you can push it in all the way. Then install the opti over it..the opti will push right down to the timing cover when engaged properly. If you can't push it flush it isn't seated correctly.
A picture might help...
http://shbox.com/1/93-94_opti.jpg
