94 Z28 Rebuild......HELP!!!
I just put my lt1 back in my 94 Z, its been 4 years since the engine wiring or trans have been in the car. I'm having a hard time figuring out the wiring harness routing through the engine compartment. What is the easiest way for me to figure this out, I was thinking having another Z pull right next to mine and take an hour to put it together. If anyone lives in the Palm Beach FL. area and has an hour to spare let me know. this car will be bad *** just need to get it done. THANKS
If you lay the harness out across the top of the Intake manifold I bet you would start to see where things go!! all the injector plugs are numbered and most everything else only has one thing it will plug into.after you get it all plugged in you can then trace where it needs to layand snap into place, you might have to unplug a few things to get everything snapped in but you'll remember what you've done at that point. Good luck!
Shoebox has a harness photo, with the terminals labeled..... would that help?
http://shbox.com/1/harness.htm
F'n1996Z28SS
08-23-2023 11:19 PM
NewsBot
01-11-2015 06:10 PM
01-05-2015 07:14 PM
