94 Z28 starts then dies Help
I have a 94 Z28 and for the past couple of weeks i have been trying to get it to run. I checked if i got spark and there was none. Then i replaced the Distributor and wires and got spark. When i try and start the car it goes into low rpm's around 500 and then dies 2 seconds later. if i give the car gas the Rpm's rise and some times i head a loud clicking noise coming from the engine. I don't have a scanner and the car isn't drivable. Also i replaced the fuel filter and checked a dozen times if the spark plug wires were in correct and in the right spots. I have not replaced the spark plugs. can some one please help me out here. Thanks
