95 Camero z28
Re: 95 Camero z28
Please tell us more about your Camaro -
- is the engine stock or modified?
- if modified, what modifications?
- what transmission, auto or manual?
- how many miles on the engine?
- how many miles on the spark plugs, ignition wires, distributor, O2 sensors?
- did you just buy the car and it runs poorly, or have you owned it for a while and it just started running poorly recently?
Re: 95 Camero z28
Usually if it happens slowly its routine maintenance things like air filter, fuel filter or other worn out parts. I've had plugged catalytic converters, burnt plug wires, bad gas and a bad distributor. Checking for codes is always the best place to start.
