95 Caprice LT1(?) into 97 Camaro SS???
Old 03-24-2008, 12:38 AM
  #16
94zgreenmachine's Avatar
Originally Posted by IdahoLT1
and let me guess, they are not compatable with the Fbodies?
I don't know if they have the torque arm mount or not. Isn't the caprice /Impala a full frame car lacking the unibody?
94zgreenmachine is offline
Old 03-24-2008, 05:00 AM
  #17
Kaj
Kaj's Avatar
we all know about the rearends in our f-bodies 96capricemgr, thanks for reminding me though....
I wish I had a couple grand to throw at a moser or even better a Dana...but the wife would probably push me into the wood-chipper...
Kaj is offline
Old 03-24-2008, 04:18 PM
  #18
96capricemgr's Avatar
Little more torque at a little lower rpm.
As guessed the b-body does not use a torque arm, just splayed 4 link and is full frame.
Fitting an 8.5" from a b-body into an f-body would come under tyhe "anything is possible, but not necessarily a good idea" catagory. If someone figured out a way to make say the slightly narrow 9C1(cop car) disc rear fit an f-body easily I bet they could make a ton on money.
The 9C1 got a slightly narrower axle as did the Roadmaster sedans, the Roady for skirt clearance, the 9C1 so snow chains would clear, the Impalas, other Caprices got a little wider and the wagons were wider yet.
They did actually use the 7.5" in some non-LT1 and non-9C1 Caprices, my car came with a 7.5 since it was a civilian L99 car at one point long long ago.
96capricemgr is offline
SinisterRacing1
03-07-2015 03:44 PM
Brandon Wittmer
12-03-2014 09:28 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
07-04-2005 05:00 PM
Burn_Out
08-18-2002 08:49 AM
Quick Reply: 95 Caprice LT1(?) into 97 Camaro SS???
