95 pcm harness wiring gauge
So what gauge is the wiring for the injectors, IAC, VSS and low oil sensor? Or if anyone has a chart for all the gauges in our harness that would be great. But those are the ones that are bad on my car. The reason I ask is because I'm pretty sure that if the wiring in your repair is a different gauge of wire then the harness the resistance changes and the pcm gets weird readouts correct? Any help is appreciated. Also where could I get this wire? Radioshack?
When I got my ewp the 30th I ordered a painless warning light with it. I wired it into the power side of the pump so when the pump is on the light is on so I know of any failures. But my question is will an 18ga wire run that light from the relay under the hood to next to my a/c controls in the car?
Thanks in advance
-Mark
Thanks in advance
-Mark
My bad. I was close tho. 3 minutes. lol
Where would be the best place to buy this wire that would make a good repair? Also does it matter if some injecotor harnesses are longer than others on the same bank? will that cause any effects?
-Mark
-Mark
Radio Shack wire will be fine. As long at the 'patch' is equal to, or a larger size (smaller gage) than the piece of wire it replaced, you will not have any problems. It does not matter if the injector wires are varying lengths. The injector function is simply a ground from the PCM to allow 12V to activate the injector. The circuit is drawing about 1 amp. A minor change in the resistance will not affect anything.
Just as important as the gage and quality of the wire is the qualtiy of the splice, and how carefully you protect the splice. Shrink wrap is always a good idea.
I know I read the sticky after that post. lol
Alright, i have soldering and heatshrinking everything so i hope i dont have any problems. the wiring is all starting to decay at the connectors. So im trying to fix everything before its running again. Also wheres the best place to ground the battery from the trunk?
While were on the topic of electric I have another question. Everytime Im at the track and I shift from 1 to 2 (auto) it wants to hit rev limiter but it shouldnt go up that high if its an auto. And i do know that I have a cracked coil (delteq) would that be the cause of this??
-Mark
P.S. Sorry for all the questions but im learning
-Mark
All my GM service manuals say the injector wires are 20 ga. (as I already posted along with the other wire gauges).
Hmm... 4 different Helms manuals I have all say .5mm which is 20 ga.
(seen in this schematic on my website)
Can you send me your email address, I will email you the sheet (Helms Manual), for some reason I cannot post attachments (probably because I am a Newbie). By the way, mine is from a b-body which could be the difference, not sure why though since the lengths arent that different.
