On a '95 Z, what sensor is RIGHT above the waterpump?
Old 08-21-2004 | 06:49 PM
warwickbass's Avatar
Thanks. The ****ing wires broke off at the connector.
Old 08-21-2004 | 08:25 PM
97WS6SCharged's Avatar
Re: On a '95 Z, what sensor is RIGHT above the waterpump?
If you're talking about the one in the intake elbow, it's the intake air temperature sensor. That's the only one I can think of that's immediately above the waterpump.
Old 08-21-2004 | 08:28 PM
Well, it's kinda placed a little to the right, but I think you're correct though. What would this affect being completely disconnected?
Old 08-21-2004 | 08:42 PM
The car will probably run a little richer as a precaution since it can't tell how hot/cold the incoming air is. The sensors aren't expensive, why not just replace it?
Old 08-21-2004 | 09:57 PM
The two conductors broke off the connector. I'd have to solder that ****.
14
08-11-2015 12:03 PM
whitehooptie
08-10-2015 07:02 AM
MikeWhitener
08-02-2015 06:17 PM
zajones
07-30-2015 02:18 PM
Quick Reply: On a '95 Z, what sensor is RIGHT above the waterpump?
