95 Z28 Cam removal
95 Z28 Cam removal
Is it possible to remove the cam without pulling the engine. My car needs lifters and when i change then I wanna put a can in it as well as roller rockers, valve springs and headers. I'm planning on doing all this together to save me the trouble but i'm not sure i wanna pull the engine on it.
you can do that if you have a lift to lift the body. If I didnt have the shop I have then i'd be doing cam swaps in the cars i've worked on. its a lil more difficult but you cant really beat the time it takes to pull the motor and do it vs. the time to do it in the car.
IMHO, one of the primary reasons for spun bearings is a bad cam swap. Swapping the cam with the engine in place requires a great deal of careful attention to the installation to ensure that no parts are damaged and no dirt is gets in. And if you spin a bearing and ruin the block, etc. you are going to have to remove the engine anyway.
I would recommend removing the engine when doing any significant mods, especially those in addition to the cam install. It is a gazillion times easier to work on the engine and do it right when the engine is on a stand. JMHO.
