95 Z28 Idle problem
Old 11-13-2023 | 05:06 PM
Ayjomi's Avatar
95 Z28 Idle problem
My z28 will idle at 500 cold and once fully warmed sit at 700ish. This is backwards isn’t it? Shouldn’t my idle be higher when cold and lower when warm?
Old 11-13-2023 | 07:02 PM
Re: 1995 z28 idle issue
PCM controls the idle RPM, along with the cold start A/F ratio, based on coolant temperature. RPM vs. temperature is dependent on transmission type. Is your trans auto or manual? The PCM attempts to maintain the idle using the idle air control valve (IAC).
There's a stock programming table of idle RPM vs. coolant temperature in my LT1 scanning guide:
https://www.camaroz28.com/forums/com...-guide-886891/
Old 11-13-2023 | 08:46 PM
Ayjomi's Avatar
I have the manual transmission
Old 11-13-2023 | 09:44 PM
It should be idling at 800 RPM fully warmed up. Do you have a way to read data from the PCM. You need to see what the IAC counts are reading if it idles at 500 RPM. That will take a program like Scan9495. Free download, just buy a cable:
https://www.camaroz28.com/forums/com...95-lt1-874306/
If the PCM is commanding the IAC to open up to an increasing number of counts, and RPM is not increasing, could be a faulty IAC, The maximum counts are 160. That would be the PCM telling the IAC to open to the maximum possible. But there is no feedback as to what position the IAC has taken. Could be faulty IAC, excessive build up on the pintle.
IAC Electrical check:
http://shbox.com/1/iac2.jpg
Resetting IAC usually doesn’t help, but worth a try:
4th Gen LT1 F-body Tech Articles
Is the idle smooth, or is it struggling and unstable?
http://shbox.com/1/iac3.jpg
Old 11-14-2023 | 06:42 AM
Ayjomi's Avatar
Do you have a link to a reliable cable? I want to try tuning a few things as well so I would like a really high quality cable. Would the homemade one be that reliable?
Old 11-14-2023 | 08:18 AM
Ayjomi's Avatar
I unplugged and replugged the iac several times with the engine running with no difference at all. So I’m gonna replace it later today.
Old 11-14-2023 | 08:38 AM
That is an unreliable test. You should check to see if there is any cleaning needed and maybe do a reset afterward.
Old 11-14-2023 | 09:08 AM
^^^^ THIS ^^^^
Unplugging it proves nothing. Don't get caught up in playing “parts replacement roulette”…. expensive way to solve a problem, usually not productive.
Old 11-14-2023 | 11:55 PM
Ayjomi's Avatar
I replaced it and 1 I saw excessive buildup and possibly oil behind the throttle blades and all in the intake manifold. Do you guys know what this could mean? 2, my car now starts idle at 2k slowly drops to 1k and stays there which is too high. Do I need to reset the pcm and relearn idle?
Old 11-15-2023 | 12:19 AM
Oil buildup in the throttle body and intake manifold can be a sign of a dirty PCV valve, or excessive piston ring blowby.
If pressure builds up in the crankcase and can’t escape through the PCV valve, it is relieved by flow reversing through the hose from the throttle body to the passenger side valve cover. Normally filtered air flows from the throttle body to the valve cover, where it is pulled through the crankcase by vacuum through the PCV valve. But when it’s relieving pressure buildup from ring blowby in the crankcase, it picks up oil mist and carries it into a chamber on top of the throttle body (directly under the cover plate). Then it drips down in front of the throttle blades and gets carried into the intake manifold.
Old 11-15-2023 | 05:52 AM
Ayjomi's Avatar
Ok sweet thank you I will check the valve also do you know the right method for pcm reset, idle relearn?
Old 11-15-2023 | 07:30 AM
Ayjomi's Avatar
What if I didn’t set pintle length? Will the computer adjust it self or do I have to take it back off?
Old 11-15-2023 | 08:00 AM
I gave you the link to the IAC reset procedure in post #7.
Old 11-15-2023 | 08:40 AM
Ayjomi's Avatar
Yes but I’m curious I did not set the pintle length. Will the pcm not set it self? Do I have to re pull it and set it?
Old 11-15-2023 | 08:55 AM
Ayjomi's Avatar
It starts at 1900 and idles down to 1000 even when warmed up
Quick Reply: 95 Z28 Idle problem
