'96 LT1, 100k miles, strange misfire. Help!
Alright, so my wife drives a 1996 TA. Lately, after the car has warmed up, it starts with a nasty misfire at idle and wants to hesistate hard when I hit the throttle. After a second of *******, and making a choked engine sound (like the timing is bad), it'll wake back up and take off. Also, when the misfire occurs, you can hear a good snap coming from under the hood, kind of like snapping your fingers. It's inconsistent though, so I don't think it's a spark grounding out.
I thought the miss might've been related to a small vacuum hose that melted on the passenger side of the intake manifold, but I repaired that and the problem is still there.
Anybody have any ideas? This car is waaaaaaay more complicated than my two cars.
Re: '96 LT1, 100k miles, strange misfire. Help!
Originally Posted by akathom
Have it scanned. Sounds like you need a new Opti-spark distributor. My T/A was doing the same thing.
before you throw parts at it try looking at it running with the hood open in a very dark place. if there are electrical snapping noises you will see them. Opti's are very expensive! They also get a lot of bad press,some warranted!
Oh, I know, I've done an Opti. I'll check the car tonight after dinner to see if I can see it shooting sparks. The snap is so loud that I have no doubt I'll be able to see a stun gun size spark if there's one.
Originally Posted by 1995greenTA
The snapping noise may be an exhaust leak. Just the first thing that came to mind.
F'n1996Z28SS
08-23-2023 11:19 PM
taner
09-09-2002 11:36 PM
