96 WS6 Low RPM Misfire Part 3....
Well I have finally had time to try a few more things on the TA to try and eliminate the low rpm misifre. I replaced the arcing MSD wires w/ some taylors as well as the coil and ICM. Thus far I have replaced plugs, wires, coil, icm, and the opti. It runs MUCH better than it did before but I there is still a very minor misfire present. It still only misfires at idle and low rpm cruising....and it will not misfire at first when cold-started but after 5mins or so it will happen. (However if you give it any more than 1/3 throttle it will clear up until u let off) So if anyone has any other ideas I can try please let me know, I'm at the end of my patience with this car and if I dont fix it soon I'm gonna sell it.
Re: 96 WS6 Low RPM Misfire Part 3....
sleeperZ96BT
06-05-2005 09:33 PM
