? about cam swap
? about cam swap
I want to install a CC503 this spring. Can I get away with just changing the valve spring? Or would I have to change the pushrods, locks, retainers, etc? I am on a very small budget. Thanks!
Later on this year, probably next fall/winter, I will buy 1.6 pro mag, 7/16 rocker studs, guide plates, and a 58mm TB. I would like to know if I can get away with not having to replace the rockers at this time. I also would like to start saving up for a different rearend.
here's what I did for my total budget setup cc503, so you can know how much you have to spend. and yes it works
10308-1 Crane Dual Coil Kit (Includes shims, locks, retainers) $166.95
http://store.summitracing.com/partde...rt=CRN-10308-1
63-1418-16 Comp Magnum Rockers 1.6 SA $189.99
http://www.thunderracing.com/catalog...vid=4&pcid=108
63-7808-16 Comp Hardened Pushrods 7.200" $38.99 (OPTIONAL)
http://www.thunderracing.com/catalog...vid=4&pcid=106
CC503 with 1.6 RR VS. Hotcam kit - How much of a difference would there be in track times (with the mods in sig)? The Hotcam kit would fit my budget a little better. I know that the CC503 would have a little more horsepower but I am more interested in track times, not HP numbers.
from what I've seen there's about a 2-3mph trap difference
plus the hot cam kit leaves little room for growth and if you decide to change your cam later down the road pretty much zero parts in the kit are reusable for bigger cams. the springs are rated for what the cam lifts, the rockers are SA.
if you feel you'll be satisfied with the hotcam's gains or don't mind redoing things later if you decide to upgrade then by all means go for it
