ABS inop light?
ABS inop light?
Guys I took my LT1 to a shop to get installed the felpro header gasket because of a leak, but now the car has the abs inop light on , does the LT1 has some sensor on the back wheels that are related to that light?
There are multiple reasons for the ABS light to come on. I would suggest looking at the front ABS harnesses for possible burns as you just had the header gaskets changed (the harnesses run down close to the headers). Yes there is a sensor in the rear (mounts at the top of the diff.); 2 sensors, one at each wheel, if you have traction control.
jj_burchiel
03-21-2015 12:51 AM
dluna333
15
03-13-2015 12:30 PM
