ABS Problem
Old 05-04-2004 | 11:30 AM
camarochick350's Avatar
ABS Problem
I have a 1996 z28 camaro. Just before this past winter my ABS light came on and its been on ever since because I havnt been able to get to the repair shop to have them check it out..... I decided to see if it was a blocked sensor. I re- adjusted the sensors in the front and in the back. I then checked the connectors under the hood. After checking the connectors the light was off for a few hours then came back on later. I'm thinking it might be a problem with the computer? Any suggestions? Does anyone know how much it might be to have this fixed?
Old 05-04-2004 | 11:35 AM
magman's Avatar
make sure that your 3rd brakelight lights are working, if not it will throw a code
1996LT1Z28
04-14-2015 07:15 PM
jj_burchiel
03-21-2015 12:51 AM
dluna333
15
03-13-2015 12:30 PM
dluna333
Parts Wanted
03-06-2015 07:11 AM
squarehead
01-15-2015 07:02 PM
Quick Reply: ABS Problem
