ac always running
ac always running
When i bought my z28 the place i got it from said that they paid 600 for new ac. It works really good and comes out ice cold the only prob is that it sort of runs all the time. When i turn it off it still comes out on my feet and where the defroster spot is on the top of the dash. I dont know what is making the ac continue to run in these spots. If this happened to anyone and they can tell me what they did that would be great. thanks in advance
Re: ac always running
Please explain more. Do you mean air continues to come out those locations with no temperature change or your fan speed does not change or the compressor does not cycle off...what?
Even with the controls off, a small amount of air will come out the floor vent and defrost when the car is moving forward. That is by design.
I assume you are giving it time to purge all the cold air out of the system after you turn it off.
Can you visually observe that the a/c clutch is staying engaged after the a/c is off? Does it blow out the dash vents when you have the a/c on normally?
10-31-2016 11:09 AM
