ac delco/autolite wires wont work
#16
#18
Re: ac delco/autolite wires wont work
Do you realize we have a spark plug reference chart stickied on the N2O Tech forum:
https://www.camaroz28.com/forums/sho...d.php?t=431689
#19
I spoke with solomon today and he believes that the mad coils are too high voltage for the wires and opti? Im picking up a oem coil in a couple hours. Im gonna spray my wires down with that hi temp silicone and give it a shot with the oem coil. If this doesnt work ill regap the plugs and throw the super conductor wires on
A plug gapped at 0.040" shouldn't be causing quality wires to arc.
Who calculated your static compression ratio?
#20
The person who built my engine. Idk how he calculates it.he has the build sheet in his office and is closed till monday. 12.4 to. 1 i have not changed my signature yet. I can't even remember specs on anything i know the heads were milled block was decked. I know it will run like crap on anything less than 93 non ethanol super.
#21
Found part of the problem. Junk plug wire sleeves. Cheap ones that look like they have aluminum foil on one side.didn't disconnect the battery. Dropped the wire onto starter and burnt a hole through it. Now wire arcs too that foily crap. Replaced it with different wire and cloth one.dielectric grease too all wires and coil plug ins. Car seems too be running great but i will wait till dark too look for any arc
#22
Problem solved. Delco wires couldn't take the heat from the headers. Put the 8.5s on and runs great. Solomon did an excellent job with the base tune can't wait too datalog it and get it fine tuned. Thanks everyone for your input
10-31-2016 11:09 AM
