AC Delco water pump question
Old 11-18-2011, 06:27 PM
  #16
bw_hunter's Avatar
Re: AC Delco water pump question
Originally Posted by JGuy07
I was told to just use some of my Permatex Ultra Black on the WP bolts, would that be sufficient?
Was also given some blue loctite for my rotor screws, I thought red was high strength but was told blue is for the smaller screws such as what is used for the rotor...
Read the packages....RTV is not a thread sealer. Thread sealer is. GM recommends the Teflon stuff for the water pump bolts.
Loctite references the permanence of the bond desired. Red is permanent, blue is removable. Use red on the rotor screws for best effect.....
bw_hunter is offline
Old 11-18-2011, 10:06 PM
  #17
Read what I said about RTV above.
shoebox is offline
HectorM52
07-30-2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
01-14-2015 02:18 AM
ANDYZ28
12-29-2014 09:13 PM
Queens94z28
12-20-2014 09:11 PM
pologreen97z
12-02-2014 10:42 AM
Quick Reply: AC Delco water pump question
