acts up when hot
acts up when hot
My car acts great for a while after I start it but after it heats up it starts to shake when I give it light throttle. It tends to do it the worst when I start moving from a stop and at low rpms in the rest of the gears. Its a six speed.THANKS for any help
Re: acts up when hot
Could very well be o2 sensors. When you first start the car it is in open loop. Once it warms up and reaches opeating temp, it will read the o2s to determine a/f ratio and what not.
Your best bet is to get a scanner on there and see how the o2s are acting. They should be bouncing up and down from like .200 to .800 back and forth.
If they are bad, www.samtaylor.com has them for 35 bucks a piece. Ask for jason chromer.
CARiD
09-07-2015 08:21 AM
