adjusing valve without oil in the motor
I adjusted my valves while doing my rebuild. Should I re-adjust them after I get oil pressure. Just a gut feeling, I think I should. Should I go with my gut?
ZMAN
ZMAN
Re: adjusing valve without oil in the motor
There is no reason to - find zero lash and depending upon who you talk to, tighten down an additional 1/2-full turn. If you set it correctly while building the motor - you should not have to do it again.
Cool, thanks. When I set mine. I turn the nut to 4 o'clock. Tighten down the lock snug, then tighten, then it looks like it turns to a 6 o'clock.
ZMAN
ZMAN
Right on. I've got another ground or 2 to hook up and plug in a few more wires, bolt up the y pipe fill the fluids, reset the valves, bleed the brakes and it should be complete.
ZMAN
ZMAN
When I did heads and cam I adjusted them once and after a few miles I noticed they started clacking more so I'm guessing once the lifters have oil in them you have to adjust some more...at least that seems to be my case.
Hydraulics are supposed to be set and forget, when you assemble the motor, give the polylocks 3/4 to 1 full turn and you will not have to mess with them again.
is this on 1:5 or 1:6 rockers equally?
10-31-2016 11:09 AM
