Adjusting RR's
Old 02-13-2008, 11:34 AM
  #16
ss.slp.ls1's Avatar
Iac?
ss.slp.ls1 is offline
Old 02-13-2008, 12:26 PM
  #17
asia517's Avatar
Originally Posted by ss.slp.ls1
Iac?
What is Iac?
asia517 is offline
Old 02-13-2008, 01:06 PM
  #18
2000GTP's Avatar
Originally Posted by asia517
What is Iac?
Idle air control valve as found in the throttle body.
2000GTP is offline
Old 02-14-2008, 10:03 AM
  #19
asia517's Avatar
bad idle when in gear???
I reset the IAC according to shbox and the car now idles fine when in park. when you either put it in gear or touch the gas it stalls. in gear the idle jumps from 500 to 1000 and back down until it finally stalls out. when you hit the gas it just goes up then stalls out. What could this be?
asia517 is offline
Old 02-14-2008, 10:23 AM
  #20
ss.slp.ls1's Avatar
It would be convenient if you could find someone to swap throttle bodies and MAF's with. Could be your IAC, could be a vacuum leak, I'm only guessing.
G-BODYT56
01-14-2022 11:14 PM
93 RedBird
11-15-2015 08:24 AM
football4life
10-04-2015 07:48 AM
SEOJustin
09-24-2015 04:39 PM
95craz28
11
09-12-2015 07:47 AM
Quick Reply: Adjusting RR's
