Advice... help?
Advice... help?
Hey, i have a 1997 Camaro Z28. The Right Front Turn Signal is out on it but i don't know how to remove the ficture or the cover to replace the bulb. Can someone tell me how so i do take the front part of my car apart.
You need to get under your car, grab a 10mm nut driver or equivalent standard size. Anyhow, start taking off the bolts that fasten the front nosepiece to the black plastic under the car. When you have enough room to get your hand up there, you can grab the bulb that is out from behind, and twist it about 1/3 of a turn counterclockwise and it will come out. Then you can put the new bulb in the housing, put it back into the lens housing, snug it up, fasten the undercar back and you're good to go.
John
John
