AFR 210cc LT4 Race Ready heads
I will assume you have an LT1 from the heads you refrence (please make and use a signature so that people can tell what car you have). I will move this to LT1 Tech as a general question like this should be posted there.
Thank you.
Thank you.
Re: AFR 210cc LT4 Race Ready heads
Originally posted by F6
Is anyone using these heads on his 396?
I need info: will I have any trouble with these heads and a 230/236 Comp Cam, as a daily driver. CR=11.3:1
other then that have fun
It is supposed to be used as a daily driver and not a race car.
Peak Hp should be at about 5900--6000 rpm and fairly good idle.
2600 TC will also be used
What hyd. roller cam would you suggest.
10-31-2016 11:09 AM
95chwagon
01-13-2015 09:19 PM
