AFR hydra-rev
AFR hydra-rev
Is anyone using afr's hydrarev kit with stock lifters? If you do how do you like it and have you had any problems. thank you
Re: AFR hydra-rev
I am with Comp R's, same thing you use the stock lifter version for Comp R's as well because its "STOCK DESIGN"
Works great! Once my outer valve spring broke and the first thing I though was thank God for the Rev kit keeping the lifter on the cam.
Re: AFR hydra-rev
Originally Posted by ForceFedZ
I got a Hydra rev kit and I was gonna use it but I decided not to cause i was using Comp 987 springs. My kit is up for sale if you dont already have one. PM me.
Re: AFR hydra-rev
Originally Posted by JustNO
My engine builder said its not necessary to use hydra-rev kit .. I use comp R series Lifters.. Why he thinks like that?? cam: 237/245dur. 582/592lifts.
Re: AFR hydra-rev
I didn't drive yet.. (assembly didn't finish yet) Cam Motion suggested this cam specs.. I think its too hard for a street/strip drivable car ,but they don't like this.. We will see (its 113 lsa >> nitrous friendly)
Re: AFR hydra-rev
Re: AFR hydra-rev
Originally Posted by SS MPSTR
I think your builder is right. Side note: how do you like that cam?
Re: AFR hydra-rev
Why do you think my builder is right?? Everybody says vice versa (they think that I should use hydra rev kit) I can't understand why there are different suggestions
Re: AFR hydra-rev
Your cam specs are similar to mine.. Which springs do you use for your 570lifts camshaft??
Re: AFR hydra-rev
Originally Posted by Cwynn
Comp 987 double valvesprings. I think that I might have to go with something slightly stronger though.
If you go with the 987 then you better get the rev kit to help in the upper RPMs where those springs may not prevent valve float. You should take a look at the LS1 beehive springs.
