are aftermarket lt1 fuel rails available?
Re: are aftermarket lt1 fuel rails available?
Nothing that will bolt right in, no.
But the OEM rails (both 93s and the 94+ style) can support some big HP. There's a very good chance that your current rails for whatever you're building will be more than adequate.
If you have a n/a setup there is no concern.
Did you read the "sticky" on the fuel and ignition forum?
https://www.camaroz28.com/forums/fue...th-gen-536421/
I have the stock rails modified to run in parallel, and several other people have done the same. Buddy of mine made 1,125HP on a blown 383ci Vortech blown LT1 using the stock rails, reconfigured to parallel operation.
hotrodyou1
12-20-2014 10:05 PM
07-04-2005 05:00 PM
