aftermarket oil pan options?
Old 02-04-2005, 11:23 AM
  #31
'93 formy ...'s Avatar
Re: aftermarket oil pan options?
I'm not argueing that Canton's had a perfect track record for their Fbody oil pan's. They haven't, as many will attest to.
However, it's far more likely you'll read about bad experiences than you would about the good ones.
It's not very entertaining to post how well your oil pan seals. Most people will just take it for granted.
If on the other hand somebody has a bad experience, they're going to want to share it.
I still stand by my old post when I said if Canton was really that bad, word would have spread by now and they'de b out of business.
I know many people with the Canton on their Fbody and none of them have problems. Then again, they're all the newer design which Canton claims to have corrected the sealing problems with that they had in the past with their previous Fbody pans.
When I finally assemble my motor, I'll let you know how my Canton seals.
'93 formy ... is offline
Old 02-04-2005, 01:00 PM
  #32
n2oblkz
Guest
Posts: n/a
Posted by: LT4383
On all these leaky Canton pans I wonder if it is the gasket and install procedure that might have something to do with it. I read several posts about people spinning bearings after doing a cam swap as well, generally that has more to do with poor install and cleanliness than anything else.
No, The threads that I have read, the guys said that they cleaned the pans and watched the oil seep through the welds! That's why you hear guys buying them and letting water sit in them for a while before they install them.
Old 03-23-2005, 05:08 PM
  #33
Birdie2000's Avatar
Originally Posted by Birdie2000
Injuneer, did you add a different windage tray to the factory pan, or are you referring to just keeping the stock one in place?
I bought a 383 blower engine that has excellent parts in it, and was well planned out, and they used the stock pan. I figure that it'll work fine since there seems to have been a lot of research done with regards to the engine as a "package", and I've seen your input and Rich's as well, but I still can't help but wonder if it's worth throwing another pan on there. If there's any simple mod to better keep the oil on the pickup in a stock pan, that would be great.
I know it's been over a month, but I'm still curious about this. Getting around to putting the engine in within the next week or two, and it's now or never, lol.
Birdie2000 is offline
Old 03-23-2005, 05:32 PM
  #34
blitz1029's Avatar
I need an aftermarket oil pan too. Where did you guys buy yours from?
blitz1029 is offline
Old 03-23-2005, 05:39 PM
  #35
DiabloGT's Avatar
what about what oil pan for a 396 with le3 heads/cam?
thanks
DiabloGT is offline
Old 03-23-2005, 06:15 PM
  #36
Crazilyconfused's Avatar
Moroso just made a custom kick out 7-quart pan for my 383. They put the windage tray, crank scrapper and trapped door baffle all into it. If i knew how to post up pics I would, but I don't. E-mail me and I can send em to ya.
Crazilyconfused is offline
Old 03-23-2005, 06:18 PM
  #37
Pasky's Avatar
Originally Posted by Brent94Z
Damn, thats sweet.
Pasky is offline
Old 03-23-2005, 07:34 PM
  #38
Birdie2000's Avatar
Sent you an email crazilyconfused.
Old 03-25-2005, 08:54 AM
  #39
mzgp5x's Avatar
Hello Birdie. I'm just up the road in Northville. Did a 383 with D1-Procharger in a 97 ss Camaro. I would like to share information. I have a Canton pan. Works OK. Very tight to the stearing rack. Can be a problem when changing a cam in the future.
mzgp5x is offline
Old 03-25-2005, 09:26 AM
  #40
Mystic97Z's Avatar
i also am in need of an oil pan for my new 355 setup, not for clearencing. my rod put a hold on my stock one.
my car is lowered, will an aftermarket larger capacity pan sit lower? i don't want to scrape the oil pan.
Mystic97Z is offline
jer4251
09-21-2020 09:42 PM
HectorM52
07-30-2017 11:46 AM
DirtyDaveW
03-15-2015 07:01 PM
Elcojoe
11-17-2014 10:27 PM
Quick Reply: aftermarket oil pan options?
