Ahhhh, the money pit
Well went up to the corner gas station. Went in and came out, click click no start. $50.00 tow home. Checked battery, good. Checked neutral saftey switch, starter solenoid disengages going into drive. Well, here is the question, if it is V.A.T.S., would the stater solenoid click? If it is not V.A.T.S., then I guess I need a new starter. What do you think?
Re: Ahhhh, the money pit
the starter solenoid should not click with the vats being bad atleast none of mine ever have. i would asume the starter. try tapping on it with a screwdriver handle or lightly with the handle of a hammer. wouldnt bang on it really hard though and be careful not to arc anything
my 96 z has done this to me 2x. both times it was cold outside just clicked clicked. these 2 times were 1 and a half years apart too. i just tried starting it later in the day when it was warmer and vroom right up it started.
good luck
good luck
good luck
good luck
NewsBot
09-30-2015 04:20 PM
