Alt issues
Alt issues
Since im running taller valve covers i had to grind the alt. When hook up the wires to the alt the car drops in idle or dies, but with out them the car holds a nice steady idle but of course wont charge. could grinding the case just a little cause this???? It still passes tests down at all the parts stores in town. Im confused.
Re: Alt issues
Got the problem narrowed down to the plug that goes into the alt. Not the power wire the only other wire. when i hook it up the car wont hold idle but it will charge when it is unhooked i get to idle but no charge. There is a small black wire that also runs down by the starter that i dont know what it goes to. i switch over to an lt4 starter and if i hook it to acc it wont crank where does it go? almost ready to go put it on dyno and see what it puts down.
Chris
Chris
Re: Alt issues
I have a 97. I had a some what similiar problem where the single wire connection post came loose inside the alt. It was causing a short in the electric system ever time I connected the red wire to the single nut post. Fixed it easy enough but the problem taking the Alt apart is that the brushes are going to pop out of their holders. You'll need some ingenuity with a pin to keep the brushes in place when you reassemble the Alt and pull the pin.
Re: Alt issues
think i may have found the issue i pulled the alt appart and fixed the loose stud and went to turn the key and lost all power. It seems i have a short in the power wire so im going to pick one up in the morning and hope for the best. Ill keep you guys up to date.
Re: Alt issues
Cable is in and installed but no luck. Could the opti be installed wrong?? Wouldnt explain why it runs fine when i disconect the alt.... Just trying to get possible solutions.
Gtpguy
01-26-2015 04:50 PM
JDohn2001
07-26-2002 05:57 PM
JDohn2001
07-26-2002 08:14 AM
