alternator bracket bolt ????
I just put a set of afr heads on my car and now the bolts that go into the head behind the power steering pump will not line up. I think i must have shaved the heads a little to much. Do you guys have any suggestions or will it hurt to leave them out?
Yes i probably could but i really hated to take it all back apart. I may try to take a dremel and grind some of the bracket and just run the bolt thats easiest to get to. I was really hoping someone would say the bracket would hold without those bolts. LOL
