Alternator plug/pigtail
is this the one that I need?
http://www.napaonline.com/masterpage...ical+Connector
I snapped the single red wire going to the plug when i pulled my alternator the other day. This one shows more than one wire though? Went to the GM dealer and they wanted $66 for a wiring harness thing (guy was an idiot)
nope thats not it.
i think its going to be a bwd (borg warner) part number pt200 which will be the part number for O'Reilly's. any other company should be able to cross reference it over to their brand.
i'll check for you at work tomorrow
That connector does look correct to me. It's not exactly like the stocker (it has a right angle boot), but the face of it is the same.
Compare...
http://shbox.com/ci/ci417.jpg
http://partimages2.genpt.com/partimages/485759.jpg
Compare...
Compare...
Compare...
Look at the pic from my site. Only one wire is used and you can see which one it is. Replacement pigtails are often going to have more wires, because they fit numerous models that use them. Just use what you need and snip off the others.
