aluminum heads
aluminum heads
I am not an expert, but i did take the car to 2 experts and they should me a stock lt1 engine and heads. My were different as well as the water pump and injectors. You could see where the intake and heads where removed, the gaskets kinda overlay the heads and intake a bit. The car also smoked a 96 vette and ran neck and neck with a 2000 ws6 with 390 hp, he had the dyno sheet.
post a pic of this engine, maybe someone did an engine swap, if the water pump is diff from an lt1... either that or its an electric water pump. wheres the thermostat at? it should be on the water pump if its an lt1.
Brandon Wittmer
12-07-2014 12:15 PM
